I am providing an online setup for P300 speller and I record the EEG signal with g.tech amplifier and I have desighned P300 speller with 6 rows and 6 columns that flash in random sequences and after that when 15 trials have been finished I want to transfer and save the data to the workspace or some address files and then make preprocessing on that signal and then classify the signal and then make a dicision and make a feedback to the subject and typee the correct data.
I wanted to save data in somewhere and then make a pause to the speller and then load the data and process it. Infact I have a mixed up online and offline analysis.
when I record the data and I want to save in workspace or sum directories it doesn't work and it says that the simulation running should be finished but I don't want to finish because I want to type different characters.
In the other hand as I want to average the different data windows I can't do it with simulink and I should do it with m.file of Matlab.
In total I can't match simulink of matlab with m.file and I have not used BCI2000 software yet.
Does anybody have any experience for online P300 speller setup for typing different characters to help me?
Best regards
Yalda Shahriari
P300speller online setup
omidsani
Re: P300speller online setup
It's probably a couple of years late (!) but you may do this using FieldTrip buffer:
http_nospam_www.bci2000.org/wiki/index. ... TripBuffer
