neurogetparams.exe
rjavadi1
neurogetparams.exe
Post by rjavadi1 » 04 Aug 2010, 11:40
We are currently using Neuroscan (SynAmps 2 and Acquire 4.3) and have connected it to the BCI2000 software. However, BCI2000 and Neuroscan are running on two seperate machines that communicate via ethernet.
I have downloaded both Neuroscan.exe and neurogetparams.exe and modified the "P3Speller_SignalGenerator" batch file:
cd ..\prog
start operat.exe
start Neuroscan.exe 127.0.0.1
start P3SignalProcessing.exe 127.0.0.1
start P3Speller.exe 127.0.0.1
I have also altered the Serveraddress to the IP address and port of the computer running the Neuroscan/acquire software:
130.199.9.1:3999
However, I can't open neurogetparams.exe to configure the system parameters. I start the Acquire server using the "S" icon and try to open neurogetparams.exe in the "prog" directory. Unfortunately, the commandline quickly flashes on my screen and dissapears.
Is there any way to fix this? What am I doing wrong?
neurogetparams
Post by gschalk » 04 Aug 2010, 15:40
You have to start it from the command line, i.e., execute cmd.exe, change to the directory that neurogetparams resides in (using cmd) and then type neurogetparams.
Neurogetparams simply prints relevant info and then terminates. If you simply click on it, it will thus just flash and disappear.
