I am running the BCI2000 v2.0. I am trying to run a P300 Web browser application. My application is able to connect to the Operator module.
However when I load the parameters file and click "set config", it throws an error -
- Row index out of range when accessing a parameter value, terminating Application module.
My parameters file is pasted below -
System:Configuration matrix OperatorVersion= { Framework Revision Build } 1 2.0 2671,%202010/02/16%2016:38:00 2010/02/17%2019:12:12 // operator module version information
System:State%20Vector int StateVectorLength= 11 16 1 30 // length of the state vector in bytes
Source:Signal%20Properties:DataIOFilter int SourceCh= 16 16 1 % // number of digitized and stored channels
Source:Signal%20Properties:DataIOFilter int SampleBlockSize= 8 32 1 % // number of samples transmitted at a time
Source:Signal%20Properties:DataIOFilter int SamplingRate= 256 256Hz 1 % // sample rate
Source:Signal%20Properties:DataIOFilter list ChannelNames= 0 // list of channel names
Source:Signal%20Properties:DataIOFilter floatlist SourceChOffset= 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 % % // Offset for channels in A/D units
Source:Signal%20Properties:DataIOFilter floatlist SourceChGain= 16 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.033 0.003 % % // gain for each channel (A/D units -> muV)
Storage:Data%20Location:DataIOFilter string DataDirectory= ..\data\P300 ..\data % % // path to top level data directory (directory)
Storage:Session:DataIOFilter string SubjectName= test Name % % // subject alias
Storage:Session:DataIOFilter string SubjectSession= 001 001 % % // three-digit session number
Storage:Session:DataIOFilter string SubjectRun= 00 00 % % // two-digit run number
Storage:Documentation:DataIOFilter string ID_System= % // BCI2000 System Code
Storage:Documentation:DataIOFilter string ID_Amp= % // BCI2000 Amp Code
Storage:Documentation:DataIOFilter string ID_Montage= % // BCI2000 Cap Montage Code
Visualize:Timing:DataIOFilter int VisualizeTiming= 1 1 0 1 // visualize system timing (0=no, 1=yes) (boolean)
Visualize:Source%20Signal:DataIOFilter int VisualizeSource= 1 1 0 1 // visualize raw brain signal (0=no, 1=yes) (boolean)
Visualize:Source%20Signal:DataIOFilter int VisualizeSourceDecimation= 1 1 1 % // decimation factor for raw brain signal
Visualize:Source%20Signal:DataIOFilter int VisualizeSourceTime= 2 2 0 % // how much time in Source visualization
Visualize:Source%20Signal:DataIOFilter int SourceMin= -100muV -100muV % % // raw signal vis Min Value
Visualize:Source%20Signal:DataIOFilter int SourceMax= 100muV 100muV % % // raw signal vis Max Value
Source:SignalGeneratorADC int ModulateAmplitude= 1 0 0 1 // Modulate the amplitude with the mouse (0=no, 1=yes) (boolean)
Source:SignalGeneratorADC int SineChannelX= 0 0 0 % // Channel number of sinewave controlled by mouse x position
Source:SignalGeneratorADC int SineChannelY= 0 0 0 % // Channel number of sinewave controlled by mouse y position (0 for all)
Source:SignalGeneratorADC int SineChannelZ= 0 0 0 % // Channel number of sinewave controlled by mouse key state
Source:SignalGeneratorADC float SineFrequency= 10 10Hz % % // Frequency of sine wave
Source:SignalGeneratorADC int SineAmplitude= 100muV 100muV % % // Amplitude of sine wave
Source:SignalGeneratorADC int NoiseAmplitude= 30muV 30muV % % // Amplitude of white noise (common to all channels)
Source:SignalGeneratorADC int DCOffset= 60muV 0muV % % // DC offset (common to all channels)
Source:SignalGeneratorADC string OffsetMultiplier= StimulusType StimulusType % % // Expression to multiply offset by
Source:SignalGeneratorADC int RandomSeed= 0 0 0 1 // Initialization value for random number generator (initialize from time if 0)
Source:SignalGeneratorADC int SignalType= 0 0 0 2 // numeric type of output signal: 0: int16, 1: float32, 2: int32 (enumeration)
Storage:Documentation:BCI2000FileWriter int SavePrmFile= 0 1 0 1 // save additional parameter file (0=no, 1=yes) (boolean)
Storage:Documentation:BCI2000FileWriter string StorageTime= % // time of beginning of data storage
Source:Alignment:AlignmentFilter int AlignChannels= 1 0 0 1 // align channels in time (0=no, 1=yes)
Source:Alignment:AlignmentFilter floatlist SourceChTimeOffset= 0 0 % % // time offsets for all source channels (may be empty)
Source:Online%20Processing:TransmissionFilter list TransmitChList= 4 1 2 3 4 // list of transmitted channels
System:Core%20Connections string SignalSourcePort= 53915 4200 1024 65535 // the SignalSource module's listening port
System:Core%20Connections string SignalSourceIP= 143.215.100.52 127.0.0.1 % % // the SignalSource module's listening IP
System:Configuration matrix SignalSourceVersion= { Framework Revision Build } 1 2.0 2671,%202010/02/16%2016:38:00 2010/02/17%2019:12:12 // SignalSource version information
System:Configuration matrix SignalSourceFilterChain= 8 { Filter%20Name Position%20String } DataIOFilter 0 SignalGeneratorADC 1 NullFileWriter 1 BCI2000FileWriter 1 EDFFileWriter 1 GDFFileWriter 1 AlignmentFilter 1.1 TransmissionFilter 1.2 // SignalSource filter chain
Visualize:Processing%20Stages int VisualizeAlignmentFilter= 0 0 0 1 // Visualize AlignmentFilter output (boolean)
Visualize:Processing%20Stages int VisualizeTransmissionFilter= 0 0 0 1 // Visualize TransmissionFilter output (boolean)
Filtering:SpatialFilter int SpatialFilterType= 0 2 0 3 // spatial filter type 0: none, 1: full matrix, 2: sparse matrix, 3: common average reference (CAR) (enumeration)
Filtering:SpatialFilter:SpatialFilter intlist SpatialFilterCAROutput= 0 // list of output channels for the CAR if used
Filtering:SpatialFilter:SpatialFilter matrix SpatialFilter= 4 4 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1 0 % % // columns represent input channels, rows represent output channels
Filtering:P3TemporalFilter int EpochLength= 600ms 500ms 0 % // Length of data epoch from stimulus onset
Filtering:P3TemporalFilter int EpochsToAverage= 3 1 0 % // Number of epochs to average
Visualize:P3TemporalFilter int VisualizeP3TemporalFiltering= 1 0 0 1 // Visualize averaged epochs (0=no 1=yes) (boolean)
Visualize:P3TemporalFilter int TargetERPChannel= 1 1 % % // Input channel for which to display ERP data
Filtering:LinearClassifier matrix Classifier= 2 { input%20channel input%20element%20(bin) output%20channel weight } 1 4 1 1 1 6 2 1 // Linear classification matrix in sparse representation
System:Core%20Connections string SignalProcessingPort= 53916 4200 1024 65535 // the SignalProcessing module's listening port
System:Core%20Connections string SignalProcessingIP= 143.215.100.52 127.0.0.1 % % // the SignalProcessing module's listening IP
System:Configuration matrix SignalProcessingVersion= { Framework Revision Build } 1 2.0 2671,%202010/02/16%2016:38:00 2010/02/17%2019:12:12 // SignalProcessing version information
System:Configuration matrix SignalProcessingFilterChain= 3 { Filter%20Name Position%20String } SpatialFilter 2.A P3TemporalFilter 2.B LinearClassifier 2.C // SignalProcessing filter chain
Visualize:Processing%20Stages int VisualizeSpatialFilter= 0 0 0 1 // Visualize SpatialFilter output (boolean)
Visualize:Processing%20Stages int VisualizeLinearClassifier= 0 0 0 1 // Visualize LinearClassifier output (boolean)
Connector:ConnectorInput list ConnectorInputFilter= 1 * // list of state names or signal elements to allow, "*" for any, signal elements as in "Signal(1,0)"
Connector:ConnectorInput string ConnectorInputAddress= localhost:20320 localhost:20320 % % // IP address/port to read from, e.g. localhost:20320
P300BrainBrowser:Window:WebBrowserTask int NumberOfSequences= 3 15 1 % // Number of stimuli sequences presented to the user
P300BrainBrowser:Window:WebBrowserTask int PostSetInterval= 120 60 0 10000 // Duration after set of n intensifications in units of SampleBlocks
P300BrainBrowser:Window:WebBrowserTask int PreSetInterval= 60 60 0 10000 // Duration before set of n intensifications in units of SampleBlocks
P300BrainBrowser:Window:WebBrowserTask int OnTime= 4 10 0 5000 // Duration of intensification in units of SampleBlocks
P300BrainBrowser:Window:WebBrowserTask int OffTime= 1 10 0 5000 // Interval between intensification in units of SampleBlocks
P300BrainBrowser:Window:WebBrowserTask int OnlineMode= 1 0 0 1 // Online mode (0=no, 1=yes) (boolean)
P300BrainBrowser:Window:WebBrowserTask string HomeUrl= http://www.google.com // The URL of the document the browser should initially load
P300BrainBrowser:Window:WebBrowserTask string TargetIds= % // Space delimited list of the XHTML id attributes of the HTML elements the user should target (if online mode is unchecked)
P300BrainBrowser:Window:WebBrowserTask int StimulusFlashStyle= 1 0 0 2 // The style of stimulus flash 0 = Box 1 = Bitmap 2 = Inverse (enumeration)
P300BrainBrowser:Window:WebBrowserTask int StimulusFlashAlpha= 255 255 0 255 // The opacity level of the stimulus
P300BrainBrowser:Window:WebBrowserTask string StimulusFlashBorderColor= 0x00FFFF 0x00FFFF 0x000000 0xFFFFFF // The border color of the stimulus box (color)
P300BrainBrowser:Window:WebBrowserTask string StimulusFlashFillColor= 0x00FFFF 0x00FFFF 0x000000 0xFFFFFF // The fill color of the stimulus box (color)
P300BrainBrowser:Window:WebBrowserTask string StimulusFlashBitmap= % // Path to a bitmap to be used as the stimulus flash
P300BrainBrowser:Window:WebBrowserTask int FeedbackDuration= 2s 2s % % // Duration of a feedback trial
ConfigConnector:ConfigConnectorFilter string ConfigurationOutputAddress= localhost:20323 // IP address to send this configuration data, e.g. localhost:20323
Connector:ConnectorOutput string ConnectorOutputAddress= localhost:20321 localhost:20320 % % // IP address/port to write to, e.g. localhost:20320
System:Core%20Connections string ApplicationPort= 53918 4200 1024 65535 // the Application module's listening port
System:Core%20Connections string ApplicationIP= 143.215.100.52 127.0.0.1 % % // the Application module's listening IP
System:Configuration matrix ApplicationVersion= { Framework Revision Build } 1 2.0 2671,%202010/02/16%2016:38:00 17:27:42%20Jun%2018%202010 // Application version information
System:Configuration matrix ApplicationFilterChain= 4 { Filter%20Name Position%20String } ConnectorInput 2.9999 WebBrowserTask 3 ConfigConnectorFilter 3.1 ConnectorOutput 3.9999 // Application filter chain
Visualize:Processing%20Stages int VisualizeConfigConnectorFilter= 0 0 0 1 // Visualize ConfigConnectorFilter output (boolean)
thanks!
nadu
