BCI2000 Classifier
Posted: 05 May 2010, 10:55
I have recorded 4 channels EEG signals in a single *.dat file for three different visual stimulus conditions (say, V1, V2 and V3) for several subjects. The file contains, few less than 60 trials for each condition, using BCI2000’s ‘StimulusPresentation_gMOBIlabPlus.bat’ file, sampled at 256 Hz.
1) Is it possible to use the existing classifier in BCI2000 to classify brain's response into three different classes (V1, V2 or V3) such that, once the classifier is trained then every new stimulus trial (of any of the conditions presented) could be classified as a seperate class?
2) How much data is required to train BCI2000 classifier?
3) How to implement a new classifier(say, SVM) offline/online, in case, if existing classifier do not work for such classification?
4) How to display output of classifier in application module, i.e. Brain's response belongs to which class (V1, V2 or V3)?
5) As an option, Is it possible to integrate LIBSVM (http://www.csie.ntu.edu.tw/~cjlin/libsvm/) into BCI2000? or BCI2000's data could be used in LIBSVM?
Thanking you in advance.
Regards
Regards
