Error: Could not make connection or dropped connection
sinverso
Post by sinverso » 20 Nov 2005, 19:37
Hi All,
If you click 'Set Config' and are greeted with error boxes for each of the modules like:
"EEGSource: Could not make a connection to the SignalProcessing Module"
and
"Application: SignalProcessing dropped connection unexpectedly."
It may be caused by the "Microsoft TV/Video Connection" in Network Connections, if you have it.
To remedy this:
1. Right-click on My Network Places
2. Select Properties
3. Right-click on Microsoft TV/Video Connection
4. Select Properties
5. Uncheck Internet Protocol.
6. Click OK.
Good luck,
-Sam
Problem/Solution
Post by gschalk » 21 Nov 2005, 09:25
Sam,
Amazing how Microsoft always manages to screw things up ;-)
Thanks for the heads up!
