My lab is interested in combining two signal sources, one from an EEG biosemi, and one from an functional near-infrared spectroscopy tool. I would like to know whether I can combine two signal sources, and if I can, how.
Audrey
EEG + fNIRS
Audrey,
BCI2000 does not allow multiple signal sources directly. However, you could utilize spare EEG channels to record additional analog signals if your NIRS equipment provides analog output, or if using a D/A converter is an option.
Alternatively, you might record NIRS signals the same way as you would record the position of a joystick. For more details, please see
http://www.bci2000.org/wiki/index.php/P ... put_Logger
