Filter output visualization
alenhardt
Post by alenhardt » 19 May 2009, 08:27
Hello everyone!
I have written a custom bci2000 module that acts similarly as the signalgenerator. Instead of generating random data, it outputs pre-recorded eeg data from a file. So far the module works as intended, the only problem is that if i check the visualize option for this module (and for the matlab filter which is a simple IIR bandpass) i dont get the option "more/fewer samples" when i right-click the visualization window.
Do i need to implement anything for the options to appear?
Also, how can i adjust the maximum/minimum number ranges in the visualization? The reduce/enlarge only seem to act on specific ranges and at some point you cant increase or decrease the zoom.
Thanks in advance
Alex
Post by mellinger » 20 May 2009, 03:35
Alex,
in recent versions of BCI2000, you should always get the "more/fewer samples" option. If it is missing, check the operator module's build date under Help->About.
The reduce/enlarge commands are intentionally range restricted to avoid user confusion. To give BCI2000 a hint regarding the proper range, set the filter output's signal properties from the filter's Preflight() function. As an example, the following code will set the output to unit range:
void MyFilter::Preflight( const SignalProperties& Input, SignalProperties& Output ) const
  Output.ValueUnit()
    .SetOffset(0)
    .SetGain(1)
    .SetRawMin(-1)
    .SetRawMax(1);
For the Matlab filter, there is currently no way to specify an output range.
Rather, the output range is always assumed to be between +1 und -1.
