I found that the parameter fragment for the G.USBamp sets AlignChannels to true, even though the amplifier samples all the channels simultaneously. (This appears to be the case even in version of bci2000 that I checked out today.)
This can cause problems when using the P300GUI program, because P300GUI does not perform channel alignment. I thought I would mention this just in case anyone else was having similar problems.
g.USBamp Alignment Filter Setting
