Hey,
I have a question about the data being saved into the DAT files. I have a matlab program that imports all of the data, and displays a lot of the header "source" information, such as the subject name, session #, and run #, in addition to all of the state variables.
After updating to the newest BCI2000 software from the website, it no longer displays the correct run numbers, although they are stored correctly in the file name, i.e. UWP47003R12, for subject UWP47, Session 003, and run 12. The run is always loaded as 01. This is not true with older data files from previous versions of the software. None of the other data is incorrect, so I don't think I am reading the data file incorrectly.
Has the change in the storage format been implemented in the new software yet? Or is it possible that the data just is not being stored correctly in the DAT file?
Thanks!
Adam
Adam Wilson
Research Assistant
Department of Biomedical Engineering
NITRO Lab
http://nitrolab.engr.wisc.edu
608-263-0008
data file format & contents problem
File format change ...
Adam,
Where exactly do you get the run number from? File name, parameter, etc.?
