I'm glad to tell you that, I fixed the problem I showed at the Workshop. However, the tests I did are still off-line because a new one rised two days ago.
I'm writing a post in order to understand with your help, a possible cause.
30/07/2008 17.39.47 - Operator started operation
30/07/2008 17.39.52 - Operation suspended
30/07/2008 17.39.52 - SignalSource: ERROR: Mode changed from: 4 to 0
startpos 6488256
ints buffered 0
_bufferCursorPos 6471680 - _oldBufferCursorPos 6471680 = 0, terminating module.
This error come out when I do some reconfiguration in the parameter settings (every parameter, also the screen resolution) or even when the SETCONFIG buttom is pressed twice.
What can I do?
Thanks in adavance.
Maria Laura
