Is it possible to update fleshing table using AppConnector (new characters for example or picture) in P300 speller, when system is running?
Can we update dynamic p300 flashing table in different way?
Appconnector and dynamic update P300 flash table
P3Speller
Kolodzim,
I am not exactly sure how you would like to update the matrix. For example, the current implementation can be configured with multiple menus, so that selection of one cell in the matrix opens up a new matrix (of potentially different size) with different entries. These "nested" matrices are described in the P3Speller documentation on the Wiki.
If this is different from what you have in mind, please post in detail what you are trying to do so that we can make a recommendation on how to best realize it.
The Gerv
The Gerv
kolodzim
P3Speller
Kolodzim,
I understand that you need to change the content of the cells during a run. This functionality is currently not implemented in the P3Speller. I also understand that the specific content of the cell is dependent on an external application.
What you need to do is to change the code of the P3Speller such that it can change images during a run. When this is done, you have to implement a mechanism to inform the P3Speller about which image to present. You could use the AppConnector to do this, i.e., setting state variables using the AppConnector that describe what's in the cells. The advantage of this is that the content of the cells would automatically be recorded in state variables, and thus in the data file. The alternative is that you implement your own TCP/IP-based protocol within the P3Speller.
I hope this helps.
I hope this helps.
