I'm using a Biosemi system with BCI2000 (P300-Speller). I want to record channels 1 to 32 and channel 257 and 258.
When I set SoftwareCh to 258, all 258 channels are streamed to disk. I don't need the channels in between.
Is there any posibility to avoid that?
Thanks in advance,
Tobias
Biosemi, SoftwareCh
Biosemi ...
Tobias,
The current Biosemi source module does not support channel selection. Thus, you will have to modify the source module to include a parameter that allows channel selection. This would be a relatively straightforward modification, and we could help you with this.
The Gerv
The Gerv
