I downloaded the Irregular Timing program as suggested on the BCI website to test our data translation board (http://www.bciresearch.org/html/irregular_timing.html). I open the program, change the board name from 'BCI_IN' to 'dt3003' and press Start, but nothing happens (no signal appears in the window at the bottom of the program). The BCI2000 program can be running or not at the same time, but the Irregular Timing program doesn't do anything either way. I also tried putting in different values for sampling rate and block size, which doesn't seem to matter either. Does anyone have a suggestion for making it work?
Elizabeth Felton
UW-Madison
Re: Irregular Timing program
Elisabeth,
I assume you named your board 'dt3003' in the DT Open Layers Control Panel? Please let me know. BCI2000 should definitely not run at the same time.
Let me know.
Let me know.
Elizabeth
Yes, the board is named dt3003 in the control panel.
Elizabeth
Elizabeth
Fixed DT3000Test
Elisabeth,
The issues with the test program are now fixed and it should work again. Please download it from the Downloads Section and let me know if it worked. Thanks.
Elizabeth
Re: Fixed DT3000Test
Yes, the new version I downloaded today works just fine.
Elizabeth
Elizabeth
