EEG source visualization speed
nadoona
Post by nadoona » 16 Oct 2007, 16:41
I noticed a strange thing in the EEG source in BCI 2000. The EEG source visualization cursor is not moving with a constant speed. The window that appear in the visualization window is 2 seconds; however, sometimes all of a sudden the cursor moves much faster than that rate. Then after a while, it moves with the normal rate again. This keeps repeating over and over.
Please advise,
Thanks.
Source display speed
Post by gschalk » 16 Oct 2007, 19:52
Nadoona,
From what you describe, it is possible that you are running a BCI2000 configuration that uses close to 100% of the processor. Please check in the Task Manager what the processor load is. It should be below 50%. In typical configurations, it's between 5-10%. If it is close to 100%, perhaps you are digitizing at really high rates. In this case, set VisualizeSourceDecimation to a higher number. Perhaps you are 'clocking' BCI2000 at a rate that is too high. This is determined by how large SampleBlockSize is in relationship to SampleRate. E.g., at a SampleBlockSize of 10 and a SampleRate of 1000Hz, the system would update the displays, cursor movement, signal processing, etc., 100 times per second.
nadoona
Post by nadoona » 17 Oct 2007, 02:41
The sampling rate is 256 Hz and the sample block size is 32 or 64. So I think 4 or 8 updates per second should not cause that problem.
Please advise.
PS. Im using mobilab as the data acquisition source.
Thanks.
Processor Speed
Post by gschalk » 17 Oct 2007, 08:03
Nadoona,
What is the overall Processor Load? What is the Processor Load of each module?
