Error System Log Operator
cmontilla
Post by cmontilla » 29 May 2026, 05:15
Script error: Could not open script file "C:\BCI2000\prog\localhost:3999". Error System Log Operator.exe
I haven't a script named "localhost:3999"
Someone can help me with that please?
Re: Error System Log Operator
Post by mellinger » 29 May 2026, 06:53
how are you starting BCI2000? From a batch file, from BCI2000Launcher, or directly from the command line?
Best regards
Jürgen
cmontilla
Post by cmontilla » 01 Jun 2026, 03:20
Using BCI2000Shell.exe
But I'm getting this error I mentioned in the operator system log.
Thank you very much for your response.
Post by mellinger » 01 Jun 2026, 10:38
BCI2000Shell works for me as expected on Windows 11.
If you give it an argument without qualifying option, it tries to load that from file and execute it as a script, hence the error message. To force the connection to "localhost:3999", use "--Telnet localhost:3999".
cmontilla
Post by cmontilla » 02 Jun 2026, 07:56
And is there any way to add that instruction so that it's taken into account when BCI2000 starts?
Thank you very much.
Post by mellinger » 02 Jun 2026, 09:20
To use BCI2000Shell interactively:
BCI2000Shell -i --Telnet localhost:3999
To execute a command:
BCI2000Shell -c "ls" --Telnet localhost:3999
To execute a script:
BCI2000Shell "myScript.bciscript" --Telnet localhost:3999
