EEG lab conversion
polivaoren
EEG lab conversion
Hi. I'm getting contradicting results when converting to EEGlab format. When I load the dat file to MatLab with load_bcidat.m function I get a signal with 197720 time points. However, when I convert to EEGlab with pop_loadBCI2000.m I get 209280 time points. What is the meaning of this difference?
Re: EEG lab conversion
welcome to the BCI2000 forum.
pop_loadBCI2000.m actually uses load_bcidat.m internally, so there should be no differences.
If the problem persists, I would appreciate if you sent me an example file for which this happens, as a private message.
Jürgen
Jürgen
polivaoren
Found my mistake. It occurred because I uploaded the filename with an event( EEG = pop_loadBCI2000(filename,{'StimulusCode'}); ). But that leads to a follow up issue/question. When I load BCI, I can go to states and find my variables (StimulusCode). But how do I access this variable after I convert to EEGlab (and without changing the number of time points as we discovered here)?
PS I tried to attach to this thread an example dat file, but the system is sending me an error 'Invalid file extension'
Events are available as EEG.events, but they are present there in "compressed" form, i.e. only changes are recorded.
If you use pop_loadBCI2000.m from inside EEGLAB, state information will be present in the GUI.
If you are not using EEGLAB, I am not sure why you would want to use pop_loadBCI2000.m instead of load_bcidat.
Upload of raw data to this forum is not possible, but you may send me a private email to mellinger@neurotechcenter.org.
