I've implemented a signal source module for a biopotential amplifier, following this tutorial:
https://www.bci2000.org/mediawiki/index ... rce_Module
The module is working, I can see the signals from my amplifier, but sometimes the signals freeze and I have to close
the program and restart, sometimes it happens immediately, sometimes after many minutes, in debug and release mode.
In debug mode, after the signals freeze, when I pause the debugging process, it stops in Atomic.h in class Compare.
I don`t know if this happened to anyone else, any help would be really appreciated.
Diana
Communication stops
Re: Communication stops
if the debugger takes you to Atomic::Compare, it is likely that you are trying to lock an already locked spin lock. Does your code use any spin locks?
Jürgen
Jürgen
dianavertiz
Hello, thanks for your answer,
I'm not sure what spin locks are so I guess I'm not using one.
A while could be an example of using a spin lock? if that's the case, then I'm using one.
Diana
Diana
OK, so it seems you are not using any spin lock. If you post your code I may have a suggestion what the problem might be. Send me a private message with the code attached if you don't want your code to be publicly visible.
