Compatibility with custom EEG device
fishcake
Post by fishcake » 04 Nov 2020, 02:26
Hi, I am curious that it is possible to use BCI 2000 using homemade EEG PCB board. Do you have any experience for that? 8)
Re: Compatibility with custom EEG device
Post by mellinger » 06 Nov 2020, 15:24
BCI2000 already supports a couple of homemade/open designs:
https://www.bci2000.org/mediawiki/index ... ModularEEG
https://www.bci2000.org/mediawiki/index ... nBCISource
https://www.bci2000.org/mediawiki/index ... BCI_Module
If you want to design your own EEG board, you will need to use some A/D component for interfacing with BCI2000. To read data from that A/D component, you will need to write a BCI2000 source module for which you may generate a template by running the program
bci2000/build/NewBCI2000SourceModule
after building BCI2000 from source:
https://www.bci2000.org/mediawiki/index ... ng_BCI2000
