GUSBAMP.DLL error with running gUSBamp with BCI2000
mliu26
Post by mliu26 » 12 Jun 2019, 23:27
I'm new to BCI 2000. Currently I'm trying to use BCI2000 to collect data from a gUSBamp with driver 3.16 with a win10 64-bit system. I downloaded the latest version of BCI 2000. However, when I try to run gUSBampgetinfo and gUSBampSource, I run into the error gUSBamp.DLL was not found. I have searched through the forum and one post mentioned to manually copy the gUSBamp.DLL file to SysWoW64 folder or the prog folder. After I did that, I was still not able to open both applications but having an error of "The application was unable to start correctly (0xc000007b)." I'm wondering if there is any solution to this? Thanks a lot.
Re: GUSBAMP.DLL error with running gUSBamp with BCI2000
Post by mellinger » 13 Jun 2019, 08:34
which version of BCI2000 exactly are you trying to run?
