Record for later playback
bci2020
How can I record signal input such that it can be played back? Is there an already compiled and working module for Windows?
Re: Record for later playback
You may use the FilePlayback source module to play back data recorded with any source module. The FilePlayback module is not part of the core distribution, so you will need to download the extended distribution in order to use it.
