I would like to modify CursorFeedbackTask and to play a .wav files on OnTrialBegin, OnFeedbackBegin and OnFeedbackEnd (3 different files).
I have found this in the API
https://www.bci2000.org/mediawiki/index.php/Programming_Reference:WavePlayer_Class
and that I need to Load a file in Initialize() using WavePlayer::AttachFile() and play it with WavePlayer::Play(). Also to use STL containers to store multiple WavePlayer instances.
I am not very proficient in CPP, so I need some help, about the location and how to give a path to the wav files?
Thank you in advance!
CursorFeedbackTask and WavePlayer
