I am following the tutorial here: http://www.bci2000.org/wiki/User_Tutori ... first_time
I have P3Speller_SignalGenerator.bat file and I have given SignalGenerator.prm file from amplifiers folder through load parameters. Next, I have added the channel names F3 F4 T7 C3 Cz C4 T8 Pz in Source tab. Finally, when I set config and press start, I can not see any significant peak in the signals and no selected character is being shown in the 2nd line of the P300 speller matrix. I think here my signal acquisition is not working correctly. I am using the OpenBCI board (32-bit) with electrodes. Note that the signal acquisition using this device works perfectly fine with OpenViBE software. Please help what could be done in this case. Thanks.
P300 Speller Signal Acquisition Issue
