CMake Warning (dev) at cmake/AddTargetMacro.cmake:131 (ADD_LIBRARY):
Policy CMP0038 is not set: Targets may not link directly to themselves.
Run "cmake --help-policy CMP0038" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
Target "BCI2000FrameworkCore" links to itself.
Call Stack (most recent call first):
cmake/frameworks/CoreLib/CMakeLists.txt:22 (BCI2000_ADD_TARGET)
This warning is for project developers. Use -Wno-dev to suppress it.
Anyway, since they were warnings not errors, I went ahead and opened the solution file that had been generated. All the projects built successfully and without errors. However, when I go to try launching a set of modules, the operator window hangs. It displays "waiting for configuration" endlessly. Windows firewall is off. This happens whether I use a batch file or the BCI2000 Launcher program. I have tried waiting for 15 minutes, but nothing happens. When I try to quit, the following error appears.
2014-10-16T21:32:32 - BCI2000 Started.
2014-10-16T21:32:33 - SignalProcessing: Waiting for configuration ...
2014-10-16T21:32:33 - SignalSource: Waiting for configuration ...
2014-10-16T21:33:40 - Error, Unhandled exception of type std::bad_cast:
Bad dynamic_cast!
Canceling thread of type StateMachine.
Close this window to quit
As an example, I can try SignalGenerator, DummySignalProcessing, and DummyApplication, and this happens. But it seems to happen regardless of what combination I try. I tried the CursorTask_SignalGenerator.bat that is recommended by the BCI200 Getting Started document. It still does this.
Any thoughts?
