Connecting UDP with MATLAB
Ramiro
Post by Ramiro » 09 Sep 2014, 10:40
Hi, I need to read the data processing BCI MATLAB to manipulate in real time, the idea is to connect with an external application. I think the path starts creating a udp object and specifying the communication port, the problem is that I can not read any data. Anyone know how the process to read the data?
Thank you.
Re: Connecting UDP with MATLAB
Post by boulay » 10 Sep 2014, 10:09
Must you use UDP, or can you use MatlabSignalProcessing? This is the better option for signal processing using Matlab.
