BCI2000 with Neurobit Optima 4
Posted: 20 May 2014, 10:39
I'm trying to test some BCI applications with a Neurobit Optima 4. I am trying to develop a real-time BCI application, but the only software the Neurobit device interfaces with is BrainBay. This software has some capabilities, but not nearly as much as BCI2000. Since BCI2000 does not work directly with the Neurobit device, I am hoping to see if some sort of work-around is possible. The software that I have, BrainBay, interfaces with the device and can export the EEG data via a COM port or TCP. It can also export the data in edf format, which I believe can be read by BCI2000, but I don't think this can be done in real-time. Can BCI2000 acquire the data sent from BrainBay via a COM port or TCP? I'm hoping to find out whether this work around is plausible or not.
Also, do any of you have experience with BCILAB? If interfacing the Neurobit device with BCI2000 doesn't work, I'm hoping to try BCILAB next. I don't know much about BCILAB yet though, so any advice on whether or not I should try it with Neurobit would be appreciated.
