Debugging "hung" CursorTask_SignalGenerator.bat
tegebo
Post by tegebo » 10 Dec 2013, 19:36
After some hacking, I got SVN trunk to build on Ubuntu 13.04. However, testing with CursorTask_SignalGenerator.bat just results in an indefinite "Waiting for connection" after setting config. I've tried modifying the batch file by explicitly setting IP/ports in addition to --DebugLevel=10, but the later seems to do either nothing or cause an unexpected crash.
What else can I do to debug CursorTask_SignalGenerator? I'd like to avoid GDB, but if that's the only option then I'd appreciate some pointers as to how to get it setup for this task.
Thanks, -ian
