Hi all,
I wrote a Python script to listen to the socket where the P3Speller would write its output. I edited the matrix to be a 3x3 one with these associations:
( Dispaly, Enter )
1 ( , 0 )
2 ( Avanti, avanti )
3 ( , 0 )
4 ( Girasx, girasx)
5 ( , 0 )
6 ( Giradx, giradx )
7 ( , 0 )
8 ( Indietro, indietro )
9 ( , 0 )
I ran a session with mouse click selection. The script listened to the socket for 30 seconds but, despite 4 successful selections, not a single "P3Speller_Output"-type output was written in the socket. Instead I found in the log file of my script output of this form:
Running 1
Recording 1
SourceTime 483
StimulusTime 491
The summary written by P3Speller at the end of the session reports correctly the 4 selections.
Where am I wrong? ^^'
P3Speller not outputting "P3Speller_Output"
Re: P3Speller not outputting "P3Speller_Output"
It seems you are reading from the UDP port used by the AppConnector to write its data to.
You should make sure that the P3Speller uses a different UDP port than the one specified in the ConnectorOutput parameter.
jfornasin
Thank you very much! It helped a lot!
