Hi everyone,
I would like to analyze recorded EEG data with the bci2000chain function in matlab. The bci2000chain usually works fine, but if I try to inculde the MatlabFilter I get the following error:
Logic Error: MatlabFilter::Constructor: Unhandled Win32 exception 0xc0000005: ACCESS_VIOLATION
Aborting MatlabFilter
I got the same error before, when I was trying to use the MatlabDemo_SignalGenerator batch. I could fix this error by downloading the modified MatlabSignalProcessing module here: http://www.bci2000.org/phpbb/viewtopic. ... 9&start=15
However, when trying to use the MatlabFilter in the bci2000chain I still get the error. Can you tell me how to fix this?
I have Windows 7 64-bit and Matlab R2012a 64-bit.
Thanks and regads
MatlabFilter in bci2000chain
Re: MatlabFilter in bci2000chain
BCI2000 chain doesn't use the full signal processing module (BCI2000\prog\MatlabSignalProcessing.exe). Instead it uses just a command-line version of the filter (BCI2000\tools\cmdline\MatlabFilter.exe).
See attached. I built it just now but I haven't tested it. Let me know if you have any trouble.
Your plan will have a Matlab function invoke a command-line program that invokes a Matlab engine. It could work, or it could go horribly wrong. Don't forget your totem http://inception.wikia.com/wiki/Totem.
- MatlabFilter.zip
- MatlabFilter commandline tool compiled for Win7 x64.
- (259.05 KiB) Downloaded 627 times
rubmoe
thanks for your reply, but unfortunately i still get the same error.
in older versions of the MatlabFilter (especially the 3.0.5 version downloadable from the web site), the access violation occurs due to a bug in code that is supposed to display an error message (awkward, I know).
The displayed message would state that one of the Matlab DLLs could not be loaded.
In most cases, the reason will be that either
* Matlab's bin directory is not in the system path (which is unrelated to Matlab's own path variable),
* or you are running a 32-bit BCI2000 executable on a 64-bit system with a 64-bit Matlab installed.
In the latter case, you might compile yourself a 64-bit version of BCI2000, or install a 32-bit version of Matlab on your machine.
