detection of G.tec
ashwini
detection of G.tec
Post by ashwini » 12 Mar 2013, 04:22
Hello everyone,
We are at the first stage of performing a P300 session using BCI2000. We were able to connect the g.tec amplifier (UB-2011.07.30) to the monitor (which has BCI2000 software version 3.0.1). but BCI2000 is not able to open the source module(G.USBampsource.exe).
The error that we are getting when we click on BCI2000-prog-gUSBampgetinfo is as mentioned:
"The programme cant start because GUSBAMP.DLL is missing from your computer.try reinstalling your program to fix this problem " .
Please help.
Ashwini.
Re: detection of G.tec
Post by mellinger » 14 Mar 2013, 10:35
You need to install the gtec gUSBamp driver software before you can use the gUSBamp with any program on a computer.
Also, if you are running BCI2000 a 64 bit Windows installation, you will either need to manually copy the 32 bit version of the gUSBamp.dll into the SysWOW64 subdirectory of your Windows installation.
