OKey i follow all the step that a ppear ont he wiki and i think it is already installed but how can i run it ?? there a re no video nor
examples i can understand.
Any one can help to run the bci on mac? im trying to capture data with an EMOTIV head set.
Thnks on advance.
Im working on :
Macbook Pro mid 2011
How to run on mac
Re: How to run on mac
you cannot use the EMOTIV head set with BCI2000 natively on OS X. You will need to boot into Windows via Bootcamp in order to use it.
In order to get started with BCI2000, please double-click the "GettingStarted" document located at the top level of your BCI2000 directory, and follow the instructions. This document is also available on the wiki: http://www.bci2000.org/wiki/index.php/U ... I2000_Tour.
Please do not only read through, but actively follow that document. Then, please follow the advice for further reading at the end of it. It will point you to the tutorials that help you perform your own BCI experiments.
