HI, in cursor task, How to set the parameter SampleBlockSize?
now the samplingrate is 128, each trial has 9s, Are there any specific standards?
thanks!
How to set SampleBlockSize
Re: How to set SampleBlockSize
in the absence of hardware limitations on sample block size, your choice is determined by the desired screen update rate for feedback. E.g., 16 updates per second would be a good rate, so a sample block size of 16 should be fine.
