Greetings. I've encountered some odd behavior running CursorTask on one of our machines. With RenderingQuality set to High, if the cursor hits a target, the applog registers the hit, but the cursor and target do not turn yellow. If RenderingQuality is set to Low, it works fine.
Also, I'm not sure if this is related, but the machine with this problem uses an ATI FirePro v4800 video card. On a similar machine with an NVidia card, this does not occur.
For our applications, we would prefer to use 3D rendering if possible, so any input on resolving this would be greatly appreciated.
Target/Cursor not turning yellow on hit
Re: Target/Cursor not turning yellow on hit
I do not think that this is a general bug in BCI2000, as this works on practically all machines I have seen. Rather, I suspect a problem with the graphics card driver for your ATI card. The best thing I can think of is to try an updated driver.
Let us know.
Let us know.
chazzd13
Gerv, thank you for the reply. Yes, the problem was the graphics card driver.
FYI, the problem is fixed with ATI FirePro Software Suite rev. 8.85.7.1
