I wonder how to save filtered dat file to analyze it in Matlab.
I know saving source signal(input) using operator, and I want to save processed data.
In visualize tab of operator module, I merely enabled it to be shown (e.g., fft output signal), but it wasn't seemed to be stored.
Do I need to change source code?
How does it work?
Thank you.
Newb question about saving filtered dat file
Re: Newb question about saving filtered dat file
KyunghoWon,
you can use the BCI2000 command line processing tools to pipe the output of your BCI2000 filter chain into a MATALB data file:
