Scan and BCI2000
kiddnesta
Scan and BCI2000
Post by kiddnesta » 20 Apr 2014, 04:38
Hi
I have connected BCI2000 and Scan for online analysis.
In the config Parameters,
SampleBlockSize
The number of samples transmitted at a time. The VisionRecorder appears to send one block each 40ms, so SampleBlockSize should match SamplingRate x 40ms.
So if the SamplingRate is 250Hz, SampleBlockSize is 10.
In the Matlab,the bci_InSignal's size is nx10,n is n channel.
Then my Matlab program must read data per 40ms.
How can increase the SampleBlockSize?
Or How do I write this program?
Re: Scan and BCI2000
Post by boulay » 20 Apr 2014, 09:30
When I used RDAServer, it had a sample block size of 100 ms. Is it possible to change the settings in the VisionRecorder RDAServer settings?
Otherwise, I think you can make the RDAClient sampleblocksize an integer multiple of your RDAServer sample block size.
I do not have access to the hardware so I cannot confirm that.
