First, a CMake error.
Using OSX 10.7 and CMake 2.8.11.2 and the BCI2000 source code updated from SVN just now (Revision: 4522).
-- Target #32: BCI2000Viewer (Tool, QTAPP)
CMake Error: Attempt to add a custom rule to output "/Users/cboulay/Documents/bci2000/build/CMakeFiles/core/Tools/BCI2000ExportQt/moc_MainWindow.cxx.rule" which already has a custom rule.
-- Target #33: BCI2000Export (Tool, QTAPP)
-- Target #34: BCI2000Launcher (Tool, QTAPP)
CMake Error: Attempt to add a custom rule to output "/Users/cboulay/Documents/bci2000/build/CMakeFiles/core/Tools/P300Classifier/moc_configdialog.cxx.rule" which already has a custom rule.
CMake Error: Attempt to add a custom rule to output "/Users/cboulay/Documents/bci2000/build/CMakeFiles/core/Tools/P300Classifier/moc_pages.cxx.rule" which already has a custom rule.If I use cmake-gui and uncheck the BUILD_TOOLS option then I can configure and generate successfully for either XCode or Unix Makefiles.
I then followed the quick start guide http://www.bci2000.org/wiki/index.php/P ... tart_Guide .
make NewBCI2000Module NewBCI2000Filter NewBCI2000FilterToolI used those tools to create ../src/custom/EEGfMRISignalProcessing and one of its filters GradArtRemoval
I then removed the intentional errors from PipeDefinition.cpp and GradArtRemoval.cpp
I then redid CMake's Build and Generate.
Then I tried to build this module and I get the following error:
Chadwicks-MacBook-Air:build cboulay$ pwd
Chadwicks-MacBook-Air:build cboulay$ make EEGfMRISignalProcessing
[ 0%] Building CXX object CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/Users/cboulay/Documents/bci2000/src/shared/filters/GenericFilter.cpp.o
In file included from /Users/cboulay/Documents/bci2000/src/shared/types/SignalProperties.h:33,
from /Users/cboulay/Documents/bci2000/src/shared/utils/MeasurementUnits.h:30,
from /Users/cboulay/Documents/bci2000/src/shared/accessors/ParamRef.h:36,
from /Users/cboulay/Documents/bci2000/src/shared/accessors/Environment.h:41,
from /Users/cboulay/Documents/bci2000/src/shared/filters/GenericFilter.h:34,
from /Users/cboulay/Documents/bci2000/src/shared/filters/GenericFilter.cpp:29:
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h: In member function ‘int ValueList<T>::Size() const’:
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h:37: error: there are no arguments to ‘size’ that depend on a template parameter, so a declaration of ‘size’ must be available
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h:37: error: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h: In member function ‘bool ValueList<T>::Empty() const’:
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h:38: error: there are no arguments to ‘empty’ that depend on a template parameter, so a declaration of ‘empty’ must be available
make[3]: *** [CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/Users/cboulay/Documents/bci2000/src/shared/filters/GenericFilter.cpp.o] Error 1
make[2]: *** [CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/all] Error 2
make[1]: *** [CMakeFiles/custom/EEGfMRISignalProcessing/CMakeFiles/EEGfMRISignalProcessing.dir/rule] Error 2
make: *** [EEGfMRISignalProcessing] Error 2There was a common error that 'foo' is not a member of 'std'. This is because both Xcode and the gcc that come with OSX default to using an older version of the standard library. One option is to simply add
#include <stdexcept>If using Xcode, click on the BCI2000 project, then in the Build Settings scroll down to Apple LLVM compiler - Language. In that section change C++ Language Dialect to C++11 and change C++ Standard Library to libc++.
That gets me further but I'm then confronted with errors I don't understand.
/Users/cboulay/Documents/bci2000/src/shared/utils/SockStream.h:262:38: No member named 'operator void *' in 'std::__1::basic_iostream<char>'
/Users/cboulay/Documents/bci2000/src/shared/utils/Lockable.h:91:7: Non-const lvalue reference to type 'std::ostream' (aka 'basic_ostream<char>') cannot bind to a temporary of type 'std::__1::basic_ostringstream<char, std::__1::char_traits<char>, std::__1::allocator<char> >'Code: Select all
if(APPLE)
set (CMAKE_CXX_FLAGS "-std=c++0x -stdlib=libc++ -g3 -Wall -O0")
endif()
If not using Xcode and using gcc, first get the latest gcc following these instructions [link]http://www.ficksworkshop.com/blog/14-co ... gcc-on-mac[/link].
For all versions of gcc I tried, I could not set the CMAKE_CXX_FLAGS -stdlin=libc++ (the other flags worked). I think that flag is not necessary with gcc, however, I once again had to edit BCIException.h as above.
Once I did that, the compile went a little further but stopped at
[ 19%] Building CXX object CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/Users/cboulay/Documents/bci2000/src/shared/utils/ThreadUtils.cpp.o
/Users/cboulay/Documents/bci2000/src/shared/utils/ThreadUtils.cpp: In function 'void ThreadUtils::Yield()':
/Users/cboulay/Documents/bci2000/src/shared/utils/ThreadUtils.cpp:132:3: error: '::pthread_yield' has not been declared
make[3]: *** [CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/Users/cboulay/Documents/bci2000/src/shared/utils/ThreadUtils.cpp.o] Error 1
If anyone out there has compiled modules successfully in OSX then please tell me which compiler you used and if you used any special compiler flags.
-Chad
