Thankyou..
p300 using emotiv
chezz
p300 using emotiv
i want to use the p300 task provided by bci2000. For data acquisition, I am usng emotiv. Please let me know how to do the interfacing of bci2000 with emotiv, for performing the already existing task. I will be able to start something.
Thankyou..
Thankyou..
chezz
Re: p300 using emotiv
I made a batch file as directed here.
http://www.bci2000.org/wiki/index.php/C ... atch_files.
the name of my file was P300Speller_Emotiv.bat
but when I try to run it in command prompt, it shows the error:
line 33: Could not open "Emotiv"
Please help.......
thankyou
Please help.......
thankyou
make sure you have a file Emotiv.exe in your prog folder. Note that the BCI2000 standard distribution does not contain the Emotiv source module, you will need to download the "contrib" distribution of BCI2000.
cahuila
Hello, I am trying to connect an Emotiv Headset to P300. I cannot seem to get it to connect. If someone has any advice it will be greatly appreciated. I run the Emotiv signal, P3 Speller Signal Processor and P300 program. It seems to start the connection but it doesn't go any further than that. Please help. I have this project for school and am using EPOC with Education Edition (Research Edition) so EEG signals from the headset is possible.
