BCI2000 and g.USBamp on Ubuntu
m.bruno
Post by m.bruno » 22 Feb 2013, 11:03
Is it possible to use BCI2000 script for the g.USBamp amplifier on a Ubuntu platform? I already have the g.USBamp Linux API C.
Thanks for your help.
Mauro
Re: BCI2000 and g.USBamp on Ubuntu
Post by gschalk » 22 Feb 2013, 15:42
You should just have to recompile the USBamp Source module with the Linux C library.
Post by mellinger » 25 Feb 2013, 09:48
Sorry, but it's currently not possible to compile the gUSBamp Source module with the Linux C library but I can quickly fix this if you send me a private message containing the header file(s) coming with the Linux C library, to which I don't have access currently, and with the name(s) of any .so/.o/.a files being part of that library.
Providing the header file(s) without library files should not violate the API licensing terms, but if you have concerns in that respect, I'll ask gtec (which will take some more time probably).
m.bruno
Post by m.bruno » 25 Feb 2013, 10:31
Thanks for the informations!
If i need other help i recontact you.
Mauro
