Problem interfacing with BCI2000
npjose
How do i interface the brain signals acquired from eeg electrodes to BCI2000??????
Re: Problem interfacing with BCI2000
You need one of the amplifiers listed on the bci2000.org web site.
taspaceem
Dear BCI200 community,
I am new to BCI and I am using Epoc head set with the research edition and I am trying to test the P300 speller of BCI2000 with it but I have problems with the batch file that I created as the tutorial here http://www.bci2000.org/wiki/index.php/C ... atch_files, it doesnot work and it does not run to configure the Emotive. So any help please, Does any one used the p300 speller with Emotiv can help?
Thank you so much
Thank you so much
In order to debug your batch file, please open a command prompt, cd to the BCI2000/batch directory, and run the batch file from there. This will allow you to read any error messages resulting from the execution of the batch file.
nm99
I have a set of EEG signals collected for specific task ,but the EEG signals are in .GNT format and each reading has a .DAT file attached to it,but EEGlab does not support that format,neither can I find some converter which can convert it to the compatible format. the system used for this purpose was Galileo Mizar. Is there any alternative to this?
Thank you in advance!
