I have a c# application connected with BCI2000 by UDP channel, at the beginning of each run I open the bci2000 from the code by opening the .bat file.with this commends
cd C:/BCI2000/prog
start operator.exe --OnConnect "-LOAD PARAMETERFILE C:\BCI2000\parms\examples\P3Speller_CopySpelling.prm; SETCONFIG"
private void button1_Click_1(object sender, EventArgs e)
Process p = null;
IntPtr appWin = IntPtr.Zero; ;
try
Process.Start("C:\\BCI2000\\batch\\ttrryy.bat");
// Start the process
p = System.Diagnostics.Process.Start(@"C:\\BCI2000\\prog\\P3Speller.exe");
// Wait for process to be created and enter idle condition
p.WaitForInputIdle();
// Get the main handle
appWin = p.MainWindowHandle;
catch (Exception ex)
MessageBox.Show(this, ex.Message, "Error");
// Put it into this form
SetParent(appWin, this.panel1.Handle);
// Remove border and whatnot
// SetWindowLong(appWin, GWL_STYLE, WS_VISIBLE);
// Move the window to overlay it on this window
MoveWindow(appWin, 0, 0, this .panel1.Width, this.panel1.Height, true);
i think the problem because P3Speller.exe open many windows not only one...
so i tried to access the sub-windows by searching for their names to use them but i could not get anything from the source code BCI2000src\src\core\Application\P3Speller
does any one have any idea how to get around this ?
thank you in advance
Thank you ………….
