1. So I don't understand wky all signals in the left are the same?
You may run BCI2000 by either using BCI2000Launcher, or from a batch file as described in the BCI2000 tour. The two ways are unrelated to each other, i.e. what you select in BCI2000Launcher does not affect what gets started when running a batch file. Also, when in BCI2000Launcher, you should not select both the SignalGenerator and the Emotiv source module because then only the SignalGenerator source module will run.
Thus, you were running BCI2000 with the SignalGenerator module, which generates a sinusoidal test signal. In your configuration, it is the same on all channels. To run BCI2000 from a batch file with the Emotiv source module, you need first to create a copy of the desired batch file, and then modify the line starting the source module such that it starts the Emotiv source module.
It also appears you did not load a parameter file as it is described in the BCI2000 tour. After starting BCI2000, first load the appropriate parameter file from parms/examples, then modify Emotiv source module parameters as described on the Emotiv wiki page. Then, save the modified set of parameters under a new name to use them later on. Alternatively, you may use the "Configure Save" button in the parameter dialog to create a parameter file that only contains Emotiv specific parameters, so later on you may load any appropriate parameter file first, and then make the configuration Emotiv compatible by loading your Emotiv source parameter file on top of the existing parameter file.
And what is showing the lower picture?
The lower window is the timing window, which is described at
http://www.bci2000.org/wiki/index.php/U ... nce:Timing
2. Why I have error in the right side of the picture?
The error tells you that your machine is too slow to properly run BCI2000 in its current configuration. Possible causes are
* You are running BCI2000 in a virtual machine,
* other applications running in the background are using up memory or CPU time.
3. Do I need to configure something else without SourceCh, SamplingRate, SampleBlockSize, ChannelNames, SourceChOffset, SourceChGain? Also please inform me what else I can do with BCI2000? What options it provide?
I suggest that you run one of the tutorials provided with BCI2000. First, take the BCI2000 tour at
http://www.bci2000.org/wiki/index.php/U ... I2000_Tour
if you have not already finished that.
Second, go to
http://www.bci2000.org/wiki/index.php/U ... I_Tutorial
and
to learn how to perform BCI experiments with BCI2000.
Finally, there is the
BCI2000 book which provides additional information about BCI2000 and Brain-Computer Interfacing in general.
