Problems with P3Speller matrix with images and AppLog window
lauramartingc
Post by lauramartingc » 14 Jul 2011, 13:39
We did an application with P3Speller matrix but instead of letters we worked with images. When we tested this application we realized that the Application Log window disappeared. Then, when we retried with the original P3Speller matrix with letters ' P3Speller_SignalGenerator.bat' , the Application Log window (applog window) didn't appear.
We don't know if it is because of the changes we did in the P3Speller matrix with images and we don't know what could happen to lose the Application Log window.
Thanks a lot!
Laura
Re: Problems with P3Speller matrix with images and AppLog wi
Post by gschalk » 14 Jul 2011, 14:22
Laura,
Check
http://www.bci2000.org/phpbb/viewtopic.php?f=1&t=1008
I hope this helps.
rebecacp
Post by rebecacp » 19 Jul 2011, 06:34
Many thanks for your response.
Our problem is the Application Log window instead of the Operator Log. After a run, a file XXX.applog is created in the data directory but we can see online this information at the Application Log window.
We tried to reinstall BCI2000 but it still doesn't work.
rebecacp
Post by rebecacp » 20 Jul 2011, 07:53
We've solved the problem as in
http://72.249.19.64/phpbb/viewtopic.php?t=479
but deleting the key APLG instead of SRCD.
Best,
