I'm new to BCI research and I am having a difficulty when running a Mu/beta session with the cursor task.
I have the Emotiv Epoc, running on an Vista operation system. I compiled the SVN and am currently using the 3.0.1 BCI Launcher. I have also followed the instructions with respect to the parameters as described here: http://www.bci2000.org/wiki/index.php/C ... ons:Emotiv
However when I launch the Emotiv Signal source, ARSignalProcessing and either the StimulusPresentation or cursor task, I get a reminder to set the high pass filter,the error is as follows:
EmotivADC::Preflight: Set HighPassFilter to 0.1Hz to filter out DCOffset.
I then set the HighPassFilter to this setting and I get the following error:
Warning: SourceFilter::Initialize: High pass corner frequency is outside sampling bandwidth. No filtering will be performed.
Can anyone explain what I am failing to do, or is this a bug?
On another point, a problem exists when I run the Cursor Task, I presume this is because there are no filters set relating to the other issue. But, the ball just keeps entering the screen and then falling to the bottom of the screen, there seems to be no data transmission with respect to the filtering.. Is this a result of the same issue described previously, or am I doing something wrong here as well.
I set the full matrix spactial filters according to that described and then used a large laplacian filter set up, around the sensors of interest., and then changed the classifier accordingly? Any suggestions greatly appreciated.......
Thanks a million for your help.
Tiernan
