An error during a P300 calibration session
shalala
Post by shalala » 07 Jun 2011, 14:48
I followed the P300 tutorial to perform P300 experiment using Emotiv Epoc headset on Windows 7 64 bits.
The calibration session went smoothly until when I created a subject-specific parameter file. After I set the matrix for Classifier using 4 values obtained from the previous offline analysis plot, I got this error when I tried to start the experiment again:
LinearClassifier::Preflight: Channel specification in
Classifier(1,input channel)=8
exceeds number of input channels.
Warning: LinearClassifier::Preflight: Specification in physical units:
Classifier(1,input element (bin))=472.7ms
does not exactly meet a single element.
I thought the number of input channels is 14, so I don't know why 8 would exceed number of input channels.
Thank you very much for your help.
Re: An error during a P300 calibration session
Post by mellinger » 08 Jun 2011, 09:11
the error message refers to the number of input channels to the LinearClassifier filter, not the number of recorded channels.
The number of channels actually transmitted to the LinearClassifier depends on the TransmitChList parameter. You should list all recorded channels there, from 1 to 14 to have them available for classification.
Thanks for pointing this out, I'll add a note to the wiki about the TransmitChList parameter.
shalala
Post by shalala » 08 Jun 2011, 20:05
Thank you very much! It works perfectly now. :D
