dear all,
I get the following error message when trying to import dat-files with eeglab, although BCI2000 EEGlab-Import is installed:
eeglab error in function BCI2000import() at line 27: Undefined
command/function 'load_bcidat'.
Could you please help me with it?
Many thanks in advance,
Sabrina
undefined function 'load_bcidat'
Sabrina Walter
Hi Juergen,
thanks for the quick reply. I tried various matlab version since then (e.g. 7.5 and 7.7) but it still did not work. I did what you recommended and then had the other error message
'there is no load_bcidat mex for your plattform available'
similarly to the one documented in the forum here. When I tried to act like described there, at the buildmex step it failed again.
You would make me very happy, if you could help me.
Many thanks,
Sabrina
Many thanks,
Sabrina
Sabrina Walter
Hi Juergen,
I am using windows xp 2002, and the error message (in this case generated with matlab 7.1 and 7.5) is this:
??? Undefined variable "CXXFLAGS" or class "CXXFLAGS".
Error in ==> buildmex at 189
mex( options{:}, CXXFLAGS{:}, LDFLAGS{:}, INCLUDEPATHS{:}, DEFINES{:}, [target '.cpp'], MEXSRC{:} );
Error in ==> buildmex at 141
buildmex( options{:}, TARGETS{i} );
Thanks again,
Sabrina
Thanks again,
Sabrina
