I'm working on visualization of brain signals and decided to write a simple external application. User will be supposed to move a ball right/left using his signals. For program to work, I read UDP packets containing control signal sent via App Connector. I use a training example, "CusrosTask_SignalGenerator.bat", with all the parameters loaded from files shown in tutorial. I get the following from UDP:
Running 0
0.0581874
Recording 1
0.0581874
SourceTime 56699
1874
StimulusTime 56704
74
TargetCode 2
56704
74
ResultCode 0
56704
74
Feedback 1
0
56704
74
CursorPosX 332
704
74
CursorPosY 2053
04
74
CursorPosZ 2047
04
74
Signal(0,0) 2
7
04
74
Signal(1,0) -0.0701226--------------------------------
When I move my mouse around, I see Channel 1 & 2 amplitudes change. However, I cannot see any connection between mouse position and what I get in UDP. Signal(0,0) is always "2" and Signal(1,0) is not the signal I see on Channel 1 or 2.
How do I aquire signal data for an external app? Is the method I'm using good for my purpose?
Best regards
