Is it possibile to be a result of BCI2000 installation? Can this problem be fixed?
Thanks in advance,
Paolo
Hi Gerv,gschalk wrote:Hi,
Are you using the neurogetparams tool to get calibration values from the amplifier, and then loading those into BCI2000?
How do you assess signal amplitudes? Online or offline with Matlab?
well, that's correct. but since the problem with the calibration appeared only after the installation of BCI2000, I was trying to figure out whether one (improbable) cause could be the BCI2000. Probably not, because I removed BCI2000 and reinstalled Neuroscan software, but the calibration problem persist.gschalk wrote:If you see incorrect values in Acquire, isn't this a Neuroscan problem?
thanks, i'll try this solution.gschalk wrote: If there is a constant factor that can correct the amplitude values, you can simply manually change the SourceChGain parameter within BCI2000 (see the wiki on doc.bci2000.org for more information on that parameter) to correct it.
