Can BCI2000 read raw eeg from emotiv epoc headset ($299)?
dvboy
iicke
Re: Can BCI2000 read raw eeg from emotiv epoc headset ($299)
As you can see on Emotiv's forums, the consumer version is protected via encryption so you can't use raw EEG. You can buy the research version for $750 for that. I've heard that somebody actually hacked the consumer version but I believe Emotiv already counter-acted against it. So, Research version is the way to go if budget is not a problem.
dvboy wrote:Can BCI2000 read raw eeg from emotiv epoc headset ($299)?
