I am a new member in BBS and this is first question.
I have a question about using signal generator and offline analysis.
Currently, our lab is focused on cursor task in BCI2000.
To verify experiment setup, I used the signal generator and offline analysis and used follow modules.
Source ; signal generator,
Signal processing ; dummy signal processing,
Application ; stimulus presentation.
To acquiring signal feature, I use ch.5(X axis) and ch.7(Y axis).
And I used left hand(Y axis, ch7) and right hand(X axis, ch5).
When I run offline analysis, I wonder that the r2 graph is right.
here is r2 graph.
this is rest vs left.(activated ch7, left)
this is rest vs right.(activated ch5, right)
this is left vs right..(activated ch7 and ch5)
Even if other channels are noise, other channels r2 value are not low.
I think other channels should have very low r2 value.
But result is diffrent.
It seems that noise channels are correlated with mouse movement.
Why that are possible?
