Wundows 7
simonuwe
Wundows 7
Post by simonuwe » 21 Mar 2010, 20:21
Could someone tell me if BCI2000 and TortoiseSVN are compatible with Windows 7? I'm just starting to use it and am having some compatibility issues. Is it worth partitioning and dropping back to xp?
Simon
Windows 7
Post by gschalk » 23 Mar 2010, 09:24
Simon,
I do not know about TortoiseSVN. BCI2000 definitely runs under Windows 7. However, Vista and Windows 7 have higher audio/video output latencies, and are thus not ideal. While it looks like with certain video drivers Windows 7 may be as good as XP, we still suggest XP for best performance.
simonuwe
Post by simonuwe » 23 Mar 2010, 09:42
Thanks Gerv,
Sounds like :o :o xp's here to stay once again....
jplucas
Windows 7 and Offline Analysis
Post by jplucas » 30 Mar 2010, 20:04
I'm running Windows 7 and MATLAB 2010a.
When I run OfflineAnalysis.m, I receive the error:
"BCI2000 Offline Analysis currently works only on windows-based systems
with version 7.x or greater of MATLAB or the MATLAB Component Runtime."
Is OfflineAnalysis compatible with my setup?
J. P.
Post by mellinger » 31 Mar 2010, 11:40
I will check this issue and report back ASAP.
--Juergen
Post by mellinger » 01 Apr 2010, 10:17
Thanks for reporting this issue. The OfflineAnalysis tool did not recognize Win64 environments correctly. This has been fixed--you should be able to run the most recent version of OfflineAnalysis from SVN, or in the upcoming April 2010 build of BCI2000, which is soon to be downloaded from here.
--Juergen
