I have a problem with the acquisition of the raw data using the biosemi2adc contribution. I downloaded the last version (the one found at: http://www.bci2000.org/svn/trunk/src/co ... e/Biosemi/).
I saw in the data visualization window some strange peaks while running the initial mu feedback recording (it also happens in the feedback session).
Thinking it was only a visualization problem, I opened the recorded files with the load_bcimat.m into matlab to double check. When I plot them I notice some problems. A series of horizontal lines appears at a more or less regular distance between each other. The signal of ch1 goes for a while to ch2, the one of ch2 to ch3 and the one of ch4 to ch1 (for instance). That way, the raw data is useless since those sudden changes are destroying my raw data.
I notice that changing the sampleBlockSize makes those peaks appear more often (if I decrease that value) or less often (if I increase that value), but I could not find a way to eliminate them always....
Does anyone had this problem before and could share a solution with me? I am a bit desperate
Many thanks in advance and best regards
aye [/img]
